Made the stupid mistake of leaving the cushions in all winter, to find them this week covered in black condensation mould / mildew !
They are fabric on the top / sides & plastic on the bottom, with removable foam infill.
Anyone tried to clean them? - had any success ? - What did you use ?
Otherwise has anyone tried to make new ones?
Any pointers gratefully accepted.
Thanx
Alan
Mouldy Upholstry !
Mine are light blue and show every mark (rust stains are the worst!) I don't know what the fabric is but it seems quite tough so I just machine wash them at 40degrees. the side cushions are easy because they just zip off but the 2 front middle ones are stapled to plywood. I undo all the staples but you need to hand wash these due to the possiblity of fraying. I suppose you could try foam carpet cleaner.
I was wondering about dying mine a darker blue does anyone know whether the fabric will take a dye?
Mouldy Upholstry !
It looks likw Welsh Wool to me, very trendy in the early 80s. You could test a small patch?
If you have a friend with a sewing machine, your fraying fears could be a thing of the past with a bit of judicious zig-zagging.
Pauline
Pauline
Post generated using Mail2Forum (http://www.mail2forum.com)Mine are light blue and show every mark (rust stains are the worst!) I don't know what the fabric is but it seems quite tough so I just machine wash them at 40degrees. the side cushions are easy because they just zip off but the 2 front middle ones are stapled to plywood. I undo all the staples but you need to hand wash these due to the possiblity of fraying. I suppose you could try foam carpet cleaner.
Upholstery
Hi all, Eventually I ended getting 2 very durable self inflatable airbeds from Great Outdoors
They are 50mm thick & are made from breathable water resistant material.
Although they do not have the slight curve of the boat, they fit ok & for the price they are spot on.
