Using a Loos tension gauge
Discussions relating to rigging
noodle
Site Admin
Post by noodle »
Hi,
I have acquired a Loos tension gauge which I plan to use to tension the rigging, does anyone have experience of using one of these, is it as simple as the instructions imply?
What tensions should I use for the Forestay and Upper/Lower shrouds?
Thanks
Andy
johnsti
Loos tension guage
Post by johnsti »
Hi Andy
I too have a Loos tension guage and it does indeed appear easy to use and to check what the existing tensions are. Problem is I have no idea what they are supposed to be and the guage gives no indication of whether the tenions are within acceptable parameters.
Did you manage to find out what the Upper and cap shroud tensions should be - if you did would you please enlighten me !
Similarly if anyone else knows what the tensions should be I would very much appreciate it if you would share the info with me.
Thanks
Ian
noodle
Site Admin
Post by noodle »
Hi Ian,
In the end I used the tensions recommended in the Loos manual for 4mm
wire and a fractional rig.
Unfortunately the manual is down on the boat at the moment so I cannot
give you the exact figures, but I get it at the weekend.
Do you have a manual?
Andy
johnsti wrote:
Hi Andy
Thanks
Ian
-------------------- m2f --------------------
Sent using Mail2Forum (http://www.mail2forum.com).
Read this topic online here:
http://www.swift18.org/Swift18/phpBB2/v ... =1823#1823
johnsti
Loos rigging guage
Post by johnsti »
Hi Andy
Thanks for your response.
No I dont have a manual with my guage all it came with was a piece of card which showed how to test the tension.
I have just had the standing rigging remade and I fixed it to the mast at the weekend so I'm very much in the dark about what the correst tension should be.
I believe the cap shrouds should be tensioned first.
Any figures and guidance you could give me from the maual would be much appreciated.
Like you I have the standard fractional rig with 4mm wire.
I have a furling jib.
Thanks
Ian
windsong
Boat Name: Windsong
Sail Number: 133
Post by windsong »
Ian,
I got this document from the old Swift site last year. It's very helpful
-----Original Message-----
Sent: 20 June 2007 09:23
To: forum-rigging@swift18.org
Subject: [Swift 18] Re: Using a Loos tension gauge
Hi Andy
should be.
appreciated. Like you I have the standard fractional rig with 4mm wire.
Thanks
Ian
Swift_18_Sail_and_Rig_Tuning.doc
(35 KiB) Downloaded 1027 times
noodle
Site Admin
Post by noodle »
The rigging document is also available on this site, see
http://www.swift18.org/technical.html
Andy
windsong wrote:
Ian,
To: forum-rigging@swift18.org <mailto:forum-rigging@swift18.org>
Hi Andy
should be.
Thanks
Ian
Cheers
Steve
<http:///Swift18/phpBB2/files/Swift_18_Sail_and_Rig_Tuning_358.doc>
johnsti
Rigging Tensions
Post by johnsti »
Hi Andy
I managed to obtain some tension figures off the internet but I'm having difficulty achieving them.
It suggests a tension of around 10% -12% of breaking strain which equates to around 150kg -180kg or around 32on the Loos scale.
Im having difficulty getting beyond 25 on the Loos scale with the bottlescrews almost fully up.
It may be that
The new rigging i've had made has been made overlong
The roller furling forestay needs tensioning up
The info i've got is wrong or i'm misinterpreting the instructions!
Before taking it down to check ,the instructions/figures from the manual / details of the Loos scale fig at which your rigging is set would be really useful.
Ian
noodle
Site Admin
Post by noodle »
Hi Ian,
Have a look at
http://www.saltyjohn.co.uk/resources/Ri ... 20Loos.pdf
For a fractional rig with aft spreaders a higher shroud tension is
recommended, so my target was 18% - 270Kg (assuming 1500Kg breaking
strain, but I see some rigging sites state 1285Kg). I found that that
all I could achieve was about 28 on the cap shrouds before I hit the
limit of the bottle screws.
I find that at 28 the leeward cap shroud seem overly slack when there is
a small amount of heel. I believe my Swift was re-rigged a couple of
years ago prior to me owning it, I wonder if measuring the length of the
existing shrouds is a wise move as they would have stretched. Replacing
them with unstretched shrouds of the same length would mean they
actually become too long once the tension is applied and they stretch.
I think mine are about 40mm too long.
Andy
johnsti wrote:
Hi Andy
It may be that
really useful.
Ian
http://www.swift18.org/Swift18/phpBB2/v ... =1829#1829
johnsti
rigging tension
Post by johnsti »
Andy
Thanks for your reply.
Must admit I had not thought about the original rigging having stretched - presumably neither had the company who did my rerigging using the old as a template !
Not sure but I guess it ought to be possible to remove the talurit eyes at the mast end and shorten the rigging slightly - in this case at least better too long than too short !
Before taking it all apart however I think I will try tweaking the forstay. The mast is certainly inclined backwards and as long as it does not pass the upright to a forward inclination it should be ok. This may give a few extra kg of load
I also did the measurements with the boom on and held by the topping lift which I understand is incorrect - not sure how much difference it will make.
At the end of the day I guess I will not really know until I get it on the water but I am comforted to hear that I am at least using the guage right and at the sort of tensions I can reach it will sail safely.
Thanks again
Ian
